Zoom Room SIP Configuration with 3cx help
nutt318
Forum User
I'm needing some help trying to get the ZoomRoom SIP configuration working and having some issues. When the room calls another extension it will ring that extension once and pop up and error on the ipad saying 'the call could not be answered because of an audio device error' Screenshots attached of the phone in 3cx and of the Zoom options along with the servers logs below. Zoom Room is ext. 411, and I'm ext. 121
Anyone have any ideas?
Thanks,
Jake
Code:
12/06/2019 10:32:24 AM - Leg L:2693.3[Extn:121] is terminated: Cause: 487 Request Cancelled/INVITE from x.x.x.x:5060
12/06/2019 10:32:24 AM - [CM503003]: Call(C:2693): Call to "My Name" <sip:[email protected]:0> has failed; Cause: 487 Request Cancelled/INVITE from x.x.x.x:5060
12/06/2019 10:32:24 AM - Leg L:2693.2[Extn:121] is terminated: Cause: 487 Request Terminated/INVITE from x.x.x.x:55251
12/06/2019 10:32:24 AM - [CM503003]: Call(C:2693): Call to <sip:[email protected]:0> has failed; Cause: 487 Request Terminated/INVITE from x.x.x.x:55251
12/06/2019 10:32:24 AM - [CM503008]: Call(C:2693): Call is terminated
12/06/2019 10:32:24 AM - Leg L:2693.1[Extn:411] is terminated: Cause: CANCEL from x.x.x.x:5090
12/06/2019 10:32:24 AM - [CM505001]: Endpoint Extn:121: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [PolycomSoundPointIP-SPIP_670-UA/4.0.7.2514] PBX contact: [sip:[email protected]:5060]
12/06/2019 10:32:24 AM - [CM503002]: Call(C:2693): Alerting Extn:121 by contact <sip:[email protected]:5060/UDP>
12/06/2019 10:32:24 AM - [CM505001]: Endpoint Extn:121: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXPhone for Windows 16.0.1.81] PBX contact: [sip:[email protected]:5060]
12/06/2019 10:32:24 AM - [CM503002]: Call(C:2693): Alerting Extn:121 by contact <sip:[email protected]:55251/UDP>
12/06/2019 10:32:24 AM - [CM503025]: Call(C:2693): Calling T:Extn:121@[Dev:sip:[email protected]:55251;rinstance=0-4dfea45a91a541fd8a305a43991a5fcb;ob,Dev:sip:[email protected]:5060] for L:2693.1[Extn:411]
12/06/2019 10:32:24 AM - [CM503027]: Call(C:2693): From: Extn:411 ("Zoom%20Room" <sip:[email protected]:5060>)  to  T:Extn:121@[Dev:sip:[email protected]:55251;rinstance=0-4dfea45a91a541fd8a305a43991a5fcb;ob,Dev:sip:[email protected]:5060]
12/06/2019 10:32:24 AM - [CM503004]: Call(C:2693): Route 1: from L:2693.1[Extn:411] to T:Extn:121@[Dev:sip:[email protected]:55251;rinstance=0-4dfea45a91a541fd8a305a43991a5fcb;ob,Dev:sip:[email protected]:5060]
12/06/2019 10:32:24 AM - [Flow] Call(C:2693): has built target endpoint: Extn:121 for call from L:2693.1[Extn:411]
12/06/2019 10:32:24 AM - [Flow] Target endpoint for 121 is Extn:121
12/06/2019 10:32:24 AM - [CM503010]: Call(C:2693): Making route(s) from Extn:411 to <sip:[email protected]:5060/UDP>
12/06/2019 10:32:24 AM - [CM505001]: Endpoint Extn:411: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ZoomPbxPhone_Windows_ZR(4.5.1119.1024)] PBX contact: [sip:[email protected]:5060]
12/06/2019 10:32:24 AM - [CM500002]: Call(C:2693): Info on incoming INVITE from Extn:411:
Invite-IN Recv Req INVITE from x.x.x.x:5090 tid=63539036fb5ca07f [email protected]:5060:
INVITE sip:[email protected]:5060;transport=UDP SIP/2.0
Via: SIP/2.0/UDP x.x.x.x:5090;branch=z9hG4bK-524287-1---63539036fb5ca07f;rport=5090
Max-Forwards: 70
Contact: <sip:[email protected]:5090>
To: <sip:[email protected]:5060;transport=UDP>
From: "Zoom%20Room"<sip:[email protected]:5060>;tag=4224ba4b5f76a10
Call-ID: [email protected]:5060
CSeq: 2 INVITE
Session-Expires: 1800
Min-SE: 90
Allow: INVITE, ACK, CANCEL, BYE, INFO, OPTIONS, PUBLISH, UPDATE, REFER, NOTIFY
Content-Type: application/sdp
Proxy-Authorization: Digest username="411",realm="3CXPhoneSystem",nonce="414d535c13fb139801:5fd22075f86437965b0f8496592c975a",uri="sip:[email protected]:5060;transport=UDP",response="8321d2313ba0b04a382e54b073809c21",algorithm=MD5
Supported: timer, norefersub, outbound, path
User-Agent: ZoomPbxPhone_Windows_ZR(4.5.1119.1024)
X-Capability: 7
Content-Length: 327
v=0
o=Zoom_VideoGW 185567 185567 IN IP4 x.x.x.x
s=Zoom VideoGW
c=IN IP4 x.x.x.x
b=AS:1000
t=0 0
m=audio 9084 RTP/AVP 9 8 0 18 101
a=rtpmap:9 G722/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
12/06/2019 10:32:24 AM - [CM503001]: Call(C:2693): Incoming call from Extn:411 to <sip:[email protected]:5060>
12/06/2019 10:32:24 AM - NAT/ALG check:L:2693.1[Extn:411] REQUEST 'INVITE' - basic check passed. No information for extended checks
12/06/2019 10:32:17 AM - Got REGISTER for foreign registrar: registrar host <sip:@phoneserver.domain.com:5060/UDP> is not mine!
My speaker was unplugged from the Zoom Room PC which was causing the issue.
This is solved.
3K8iMGWviZ
