If you’re still running a FreePBX®, Elastix or Askozia PBX then now is the time to beef up your communications tools. Converting to 3CX V16 has never been easier with our new online converter tool, it consists of just 3 simple steps:
- Take a backup of your current PBX.
- Upload the backup to our tool.
- Export the configuration and install 3CX.
Head over to the Online Configuration Converter tool.
During conversion the below elements of your old PBX are also converted to 3CX, saving you heaps of time on re-configuration:
- Extensions
- Trunks
- Inbound & outbound rules
- IVRs
- Blacklist
- Feature codes
Your Free 3CX license
In addition to the free conversion, you get a free 3CX license with a free PRO Edition trial for unlimited users. Fill in the form to receive you free license key via email.
Using a telephony card?
If you're still using a telephony card to connect to the PSTN, we recommend you to upgrade your existing lines to a SIP Trunk from one of our supported VoIP Providers but in the meantime, you have these alternatives:
* FreePBX® / Asterisk® is a Registered Trademark of Sangoma Technologies. This trademark is not affiliated with 3CX, its products, or its websites. Sangoma Technologies is not the source of, and does not sponsor or endorse, the products/services promoted here. 3CX is not associated with or sponsored by Sangoma Technologies. All product and company names are trademarks™ or registered® trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them.
