İphone phone not ringing
elc
İphone phone not ringing,
Hi @elc
I wonder what is the app version and OS in the iphone?
Did you check the pbx event logs? do you see any error/warning event related to the call?
Using WiFi and mobile data is the same?
is it with a specific user or with any user?
Almost every iphone we use OS 16.
I check pbx logs, I dont see any error or warning its not reach phone ı guess because when app open still not ringing the phone.
I try local network and mobile data its give same result not ringing,
Any user result is same
Could you please in the extension the following:
Go to forwarding rules --- Available --- the field Accept Push Notifications must be enabled
Then go to Phone Provisioning --- 3cx app ---- the field Enable Push notifications must be enabled.
Validate that the extension is using the Available Profile.
Then from the pbx management console -- go to settings ---- network --- disable Automatically Bind to IPv6 Adapters and restar the SIP service.
Go to security ---- anti-Hacking and check the field SSL/SecureSIP Transport and Ciphers is enabled.
In the smartphone check the same does not have the DND enabled.
In your network since this is a on premise installation check you are using the google dns and allow the traffic to these domains
Then try it one more time.
Firstly before these ı dont change anything but iphone phone not ringing. I checked your solution method and everthing same to your result. And nothing changed. How to solve these problem.
Hi @elc please kindly ask to your 3cx partner assigned to open a technical support ticket with us, in this way he can submit the pbx logs to analyze them.
Thanks!
Hi, I inform my 3cx partner to open technical support ticket. After that you contact to them or me.
@elc great we will take it from there.
Academics Excellence Ja
