Solved *2 call pickup
kurt5132081
Forum User
Hi Guys
i would like to know if there is a way to limit this to a specific group of extensions.
I have a v15 server running the latest service pack and extensions broken down into multiple groups per department, however when users dial *2 (which they are used to doing from an older system which was replaced) they pickup a call from a different department.
Hence the question is it possible to limit call pickups to group members?
Check the phones are not a member of the default group if you have created new groups - phones can be members of more than one group
Management Console - Groups
Also check Settings -> PABX Settings - Limit Call Pickup to calls received in their extension group
This should be ticked
None of the ext belong to more than one group.
there are not global rights enabled on groups either
BINGO!!!
missed this, thank you!!!!
Bluebox Global
