- Joined
- May 21, 2023
- Messages
- 14
- Reaction score
- 1
Hello Everybody,
I am facing one issue recently I brought 2 SIP connections from the Same ISP. The issue is their SIP server is the same address for both Trunks. I already defined the Static route in our firewall to reach the sip server from Gateway-Sip1 which is Trunk-1. But every time I have to switch the route for Trunk2 to use Gateway-SIP2. For instance, details are mentioned below.
SIP1
WAN1 IP: 10.170.X.238/30
GW: 10.170.X.237
DID-DOD: 5785690-98
SIP2
WAN2 IP: 10.150.X.210
GW2: 10.150.X.209
DID-DOD: 5785680-89
SIP Server IP: 10.138.120.249/32
10.120.140.230 via GW1: 10.170.X.237
10.120.140.230 via GW2: 10.150.X.209 I can't add a duplicate route in the firewall to the same SIP server.
I hope you understand my concern and the issue, Please advise.
SIP1
GW: 10.170.X.237
DID-DOD: 5785690-98
SIP2
GW2: 10.150.X.209
DID-DOD: 5785680-89
