Solved *20* not working.
Paul Fouche
Trainee Partner
Hi All,
Did a new build in Gcloud and an SBC on site.
Client requested that *20* change to *30* which i have done.
Rebooted the server.
Since the server has been built we cannot pick up any calls.
We get the response of "no action performed"
Anyone ever had this?
Reactions: phonemaster
I had a custom recently reported something similar actually.
What I would ask is if you go back to *20* does it work again? Also is this a global pick up or per extension group?
Reactions: Paul Fouche
Hi All,
I think you "crossed" it with the 'Change Profile Status' dial code which is *3(0,1,2,3).
Try to change them. So, if you need 'Pickup a call' = *30*, then change the 'Change Profile Status' to something that is not "crossing" with other dial codes - let say *66.
I would agree with @phonemaster on this one. When changing the dial codes you need to be careful so that dial codes are not overlapping.
Hi All,
Ill be trying this shortly and letting you know how this works.
Thanks again!
just the standard pickup dial code
Hey this worked like a charm.. i changed the Change profile dial code to *8 and it started working.
What a legend!
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bastion Advisory
