Solved 3cx and Zoho CRM integration - "invalid client" - "client ID passed does not exist"
linked2u
I am following the instructions to connect my 3cx pro v20 to Zoho CRM - https://www.3cx.com/docs/pbx-crm-integration-zoho/
When I reach the point where I need to authorize in 3cx after entering the client ID and the secret, a page opens that says "invalid client" - "client ID passed does not exist."
I am using a Zoho.com server. My 3cx is self-hosted with Google Cloud.
What might be the problem?
Are you sure you created the app in the right datacenter as well? Those are not global.
What @ConceptsWeb mentioned is that it might be required to use a different server URL based on your location. This is also mentioned in the guideline:
You might need to clarify this with Zoho as well.
Thanks, i changed it to .eu and its working now
