3cx Android app not ringing in phone's DND even when set to bypass the mode
unitthk
Heya. I'm having some issue with 3cx on my phone. When the phone is set to DND mode, 3cx shows the notification that there's an incoming call, however it doesn't ring, only vibrate.
The phone's volume is set to max, and it happens both with the ringtone option set to 3cx or phone's ring tone.
Phone rings fine outside of DND. I see this has been raised in the past but that thread is locked now.
I'm on a Galaxy A35, Android 16.
App version 20.6.0
Can someone help? Thank you
Check your DND config of your phone. There must be something wrong.
I've suspected that, however other apps that's also put on the whitelist (Facebook Messenger, Zalo, or just normal phone calls from contacts) are put though with audio just fine. Only 3cx itself is having the vibration-only call notification
LeeonLau
