3CX Announces Multi-Tenant Capability
I actually just played with this a little, looks to me like you set the role as the user and there isn't any provision for changing the role in different departments.
This is sad, because it prevents to use Roles model with groups (like a department) for fully ... like a model in MS Active Directory, for example..
Thanks for the set of features in the Departments!
But I can't find feature request... May be it's possible?
"A user can have different roles in different Departments"
Well we believe that an ideal user will work in one role in a company from a management view (for example he is a head of a Sales department) and potentially can have extra call-related roles in other departments (for example he manages a calls in Italy Support Department). Such roles we internally call "observer".
P.S. Admin Console is an app that shapes API in a certain way. The way we envision it. There's no restriction from XAPI or PBX point of view on different roles in different departments. But this needs to be done via XAPI and might potentially break editing of such user in Admin Console. Just keep it secret) And it is unsupported area I would say.
Bulk editing is coming
separate phonebook per department is coming
select outbound caller ID will come on a user and per call basis, I.e. you can select your outbound route and caller ID from the app dial pad
Hi Nick,
The bulk editing is already back. Many thanks to that.
Can you give us a roadmap for the separate phonebook and outbound caller ID selectable per call features.
Bulk editing ✅
separate phonebook/department, expected in U8
select outbound caller ID per call, expected??? U9???
Jake_Southern
