3cx assistant and outlook RIGHTS
bluetel2
Hi all,
we have problème with 3cx assistant and outlook contacts.
it's only works if the user is an administrator or have administrator privilège. do you know solution to use 3cx assistant and outlook contacts in domain with restrcitives users.
it's on 3cx V8
Tks
Vali_3CX said:
Hi, bluetel
Please tell me 3CXPhone version (the one listed in its About). We had an issue at one time related to what you said, and it has been fixed but not released yet.
vali
Hi Vali, the version of 3cx phone is 4.0.9530
Well, we will send you a more recent version, to test it and to see if it works - I'm almost sure it will 8)
Regards
vali
Regards
vali
i had test the version of stefanW 4.9551. it's work for my usb headset (plantronics) tks, but not for the usb speaker (ringing). it's generic brand usb speaker...
regards
regards
Thanks for feedback.
Well, if the administrative rights issue no longer appear, then we can consider it fixed. For Plantronics issue, please open a new topic for it, to can deal in depth with it.
Regards
vali
I also have a same problem with Assistant, that not connect first time, but only after refresh.
We are currently fixing these kind of issues in the assistant at the moment already.
It will propably be available in the next assistant release.
AshleyStokes
