3CX Backups And Vultr Object Storage Question
Leo_B
Hello 3CX fellows,
Has anyone experienced with setting up the Vultr Object Storage as an external cloud location for 3CX daily backups? Considering the one is S3-powered, I can mount the S3 busket as a local folder, but failed to save a backup archive properly. The server accepts the location as well as reports the backup task succeded. However, the backup file appears to be zero sized.
Still trying to find a way to fix this.
Hi Leo,
The only bucket solution we natively support currently is Google, but you can use either local drives or block-level write access drives like SAN / iSCSI.
File-level access is not supported (writes are not confirmed, you risk data loss).
So if your solution is not mounted as block-level, I'd expect it to fail.
tohoken1
