Solved 3CX Bridging
eds.pare
Hi, We are currently trying to setup a 3CX Bridge.
1 is in azure(debian 9 3cx v16) and one in some remote site( windows v16 with static IP).
Under Event Log.
  • Registration at **************-Bridge has failed. Destination (sip:127.0.0.1:5080;lr) is not reachable, DNS error resolving FQDN, or service is not available.
    SIP Server ID: 12293 10/12/2021 9:59:12 AM
    SIP Server ID: 12293 10/12/2021 9:59:10 AM
    SIP Server ID: 12293 10/12/2021 9:57:50 AM
Under Activity Log.
10/12/2021 9:59:12 AM - [CM504005]: Registration failed for: Lc:10101(@**************-Bridge[<sip:10101@**************:5090/UDP>]); Cause: Cause: 503 Remote end of tunnel is not connected/REGISTER from 127.0.0.1:5080
10/12/2021 9:59:10 AM - [CM504005]: Registration failed for: Lc:10101(@**************-Bridge[<sip:10101@**************:5090/UDP>]); Cause: Cause: 503 Remote end of tunnel is not connected/REGISTER from 127.0.0.1:5080
Via email notification
Registration at ************-Bridge has failed.
I did follow the 3CX guide lines.
IF i don't use the tunnel, the error will be unknown user.
  • Call or Registration to ************-Bridge has failed. sip:10101@************:5060 replied: 404 User unknown.; from IP************:5060
    SIP Server ID: 12294 10/12/2021 10:25:47 AM
  • Call or Registration to ************-Bridge has failed. sip:10101@************ replied: 404 User unknown.; from IP:************:5060
    SIP Server ID: 12294 10/12/2021 10:24:21 AM
Any idea? Thank you
Oh nevermind this. i have fixed it.
Hi @eds.pare, glad to hear you resolved the issue. If you'd like to add what the solution was, feel free to.
oh a bit lack of knowledge on my part.. one is i put different virtual number.
And the machine i used got a host file configuration.
Rich Hopkins
