Solved 3CX CTI with windows
Olivier_Livi
Platinum Partner
I have a problem on 3CX for Windows (CTI) all works well except when the pc stops.
At the next reboot the software returns to softphone and I can not find options in the software to always pass it in there is an option or an ini file to change.
I am concerned about several 3CX version 15.5
or during a restart of the application.
You can change the default settings - Edit the Extension, Phone Provisioning - Select 3CX Client and change Call Control.
You need to change this to IP Phone.
Hello Olivier,
I would strongly recommend to use the 3CX WebClient for CTI as it superior to the legacy CTI of the 3CX Phone and also available cross platform (PC Mac Linux)
Thank you all for the answers Saqqara you have solution works well
Bye
Rich Hopkins
