3CX Debian OS Update Failed
Hamzeh Mahafzah
Forum User
3CX attempted to update your 3CX Debian OS from Debian 10 to 12 and failed.
This may be caused by changes made to the OS after installation. The attached log file shows where the update failed.
attached is the log file.
any help or support to update 3cx to v20?
Edit: The log file has been removed for security/privacy reasons.
debian@vps-9fdd07e0:~$ cat /etc/debian_version
12.7
I need to execute step 5?
already installed and updated to v20 finally :)
Yes , change firewall settings ( Ports Forwardings )
5060 UDP/TCP
5090 TCP/UDP
5001 or 443 TCP
9000-10999 UDP
where i can found firewall settings ( Ports Forwardings )?
The settings in the router where the 3CX telephone system is located.
What is the brand and model of the router?
i am using cloud server
maybe I use in premises installation, which coz this issue?
must to change default ip interface
You have only one interface, right ?
3cx server on the cloud and it have a static IP all user connect directly and all ports open their.
i do installation from my laptop not via server
OVH is not supported by 3CX, which complicates your setup. You should look into adjusting OVH settings to allow incoming traffic to your server. It appears there are missing configurations related to NAT at OVH.
Here's a link to OVH's guide on configuring NAT
I cannot provide further assistance since this involves troubleshooting OVH-specific issues, and we do not have tools for that. Consider contacting OVH for support or switching to a supported hosting provider.
clear.
but before update to v20 it was working perfectly without any setup
also I missed special integration template with the new update :(
clear.
To function, there are two solutions:
Either the VM is not behind a NAT,
or there are configured rules.
This is the foundation of any network.
Please be more specific.
DrunkeMeister
