3CX Enterprise Failover v16
Scot Busby
I have setup the failover process as described in the documentation provided by 3CX. It has been running for about a week doing the restores regularly - with success. I had an opportunity to test the failover process yesterday by downing the main server. After the pre-set time, the passive server became active and all seemed well. I placed a test call...but nothing happened. In the failover management console, I can see the incoming call, however, none of the digital reception recordings were playing and nothing seems to happen, regardless of the options pressed.
I downloaded some of the recordings from the failover server, but they all sounded good. The SIP trunks were registered and I could see my incoming calls.
I am sure I'm just missing something small, but wondered if anyone else has experienced this?
It does that when you first boot it up and it detects it for the first time.
The services are stopped while in passive so not 100% sure if it will update until such time as it becomes active and services are all up.
I was thinking this might be what's happening. Just shows as "detecting" if/until it becomes the active server. I will probably find out since I plan to see if all these testing scenarios work as I continue to lock this down. :) Before I test further, I need to look at what pre/post scripts are available and what they do so I can take care of ensuring services are stopped and started appropriately if a failover occurs. Thank you again for all your help.
Reactions: JohnS_3CX
Wecare_ITA
