3CX Enterprise License high avilability feature:
nobody
How is this done regarding the license? Can I just install the same license a second time?
TIA
with enterprise, you get two licenses. One main and one standby
Both are the same license
ok, maybe I formulated my question not exact enough:
Should I geht two license keys or one (I only got one)?
You need to buy 2 PRO licenses or one ENT license to install twice. If you have a PRO license already you can upgrade it to ENT. If you are not working with a partner already we can help with that.
sorry, I try again to formulate my question (I am a 3cx partner):
I bought an enterprise license.
I got only one license key.
Can I use this license key I got to install the second instance or did something go wrong and 3CX missed it to give me the second key?
Gotcha. If you have an enterprise license already then you can install it twice. It's flagged in the backend to allow two active instances with the same key.
Reactions: YiannisH_3CX
Thank you! That was what I needed to know - everyone does some things the first time.
To my knowledge, you are not allowed to install 2 different 3CX Installations with one ENT key (eg. 2 different FQDN´s). The ENT key is for redundance of your primary installation or to get the extra functionality given by a ENT license. - however I might be wrong :-)
florentrobineau
