3cx free?
angelo1
Trial User
I was under the impression that the software was free under 10 users.
Now after I've spends countless hours configuring it it says that it'll we be deactivated march 15 and I need to buy a license?
This really sounds like a scam.
Why are you advertising that is completely free and now after I'v invested all this time I need to pay?
Could you give me one good reason to pay after your deceiving tactics?
angelo
The Free version of 3CX is 3CX SMB FREE, looks like you did a Free Trial,
It says:
3CX PRO 4 SC
And it's the one they are promoted, the only one.
It says that the subscription expires March 15
Is there another version?
It says:
3CX PRO 4 SC
Yes there's the SMB Free which is cloud-hosted by 3CX.
You chose a dedicated Pro license trial. Not the same thing at all.
You know, that's why there are partners like us here to assist you with making the best decision and understanding the differences between license types.
angelo
Hi Angelo, just for clarity - there are a few versions of the product.
There is an entirely free version, and it sounds like you maybe want the one - hosted by 3cx, with some feature limitations, but is free forever / and supports 10 ext (or fewer) and so long as your SIP trunk is with a supported provider.
The "free trial for time limited period" version differs by design in that - it gives you more features, flexible options, intent is for a bigger deployment 'try before you buy'
So, assuming you have a config you are happy with, and you have 10 EXT or fewer, most likely you can simply
- proceed to sign up a new-from-scratch free-forever small business 3cx instance that is hosted by 3cx. You are basically getting a slice on their 'shared 3cx server'. The price is right (free) and you get by design a certain scope of features
- with your expertise learned on getting your other instance setup and working, it should be very easy to configure the new free instance
- then you can go forward from there, let the 'original free trial but not free forever' version expire and go away. You can keep using the free forever version.
- and if you need a bigger PBX down the road, you may possibly be happy to pay for the non-free version of the product, which has more features and supports more users, more concurrent calls, etc.
given that the free-forever smb 10-ext-or-less version has a lot of functionality, ie, a very nice modern smartphone app / browser app / etc. - then possibly it will do what you need-want and this is a good outcome.
Tim
circusduck
