3CX in Cluster VMs
Yiannos Ioannou
Gold Partner
Hello ,
A Question if anyone test it
Lets say i have a VM machine in a cluster setup of 3 host.
The 3cx is on the Host A . In Case of Host failure all the machines that are on the host A will migrate on the Host B or Host C. In that case the 3CX will work on the Host B ?
Not really a 3CX question and if you really care that much it's something you would just test yourself unless you are planning on building a cluster based on word of mouth and solely for 3CX. But to answer your question the whole point of a cluster is that it keeps the state and all relevant bits with a floating IP address. Can't say that I've tested it but it should work in theory although I'd bet any in-progress calls would drop.
jmarshall
