3CX Integration Phonemondo
imux24
The CRM integration can only report calls after the call ended. There is no way to update an entry in realtime at the moment.
You may wanna look into the REST API of @VoIPTools for this.
Reactions: edossantos
Thanks, i gave up and switched to tapi..
Robert Lee
