3CX integration with Custom CRM
Sivarajan R
Platinum Partner
Hi Team,
we are working with CRM Provider to working for 3CX integration with CRM , its web based CRM , after implement template its able to show the lookup in the 3CX , but the challenge is CRM not able to send CDR details after end of the call its not hitting the api, we are not getting any error msg also , could you please help us to achieve this , how we can troubleshoot this , the log should send to api after end of the call so the api can display in webhook , here its not happening , but when call arrive the call log registration is happening , could you please help us in priority basis.
Regards,
Sivarajan R
Hi Team,
Regards,
Sivarajan R
You need to check the 3CXSystemService log in verbose to figure out the CRM integration issues. Search the file for "CRM".
It's in Activity Log > Logs > Instance.
A 950€/year API for this is quite overkill.
I dunno, it does come with tech support. With some of the questions on this forum I don't know if that would be enough for me to deal with them! :rolleyes:
gmacinit
