3cx license limit is reached active calls
Simone Rota
Forum User
Is there a way to set a different message so the caller understands that the number is "busy"?
Other than "Limit is reached....."
Simone Rota
Yes, change the prompt file in Settings > System Prompts.
Well technically the message is correct. If you have trunk capacity and you have the users to answer the phone then you aren't 'busy', you just haven't paid for a large enough license :) . But otherwise you can lower the trunk simultaneous calls in 3CX, you can adjust the call concurrency with your provider which will generate a busy tone or you can change the recording as @Frederick Marcoux explains.
Lowering the simultaneous calls on the trunk won't take the internal calls into account tho. Which might still result in a 'limit reached' message
You are right but if after decrease of SC on trunk there's always messages with limit reached, then for sure a higher SC licence is needed.
It will not let you browse for a new file for the LL prompt. How would you change that
Jordius
