3cx Listening in a group?
AdStar
Forum User
I am wondering because I seem to not be able such option.
Story is: I configured 4 users in a single group, everybody inside this group are set up to be able to listen in other calls. They are not in queue. Only inside a group.
Question is, how they can listen each other as there is no option inside a group like right click -> listen it as it is in queue. Is new queue only option in this case?
They need to do this from the panel view of the client.
Barge in, listen in or whisper are paid features so they won't exist in the Free version.
If you have the paid version, then your user needs the correct rights:
https://www.3cx.com/docs/access-roles/
That would be either Manager and Group/System Owner
Then you go to the panel during an active call, right click and you will see the options appear there.
We are in paid version, Rights inside group are set - everybody is set as group manager with listening option checked. But I am not able to find such option in 3cx App. Check below screenshot, there is no Listen option
Use another view like receptionist
Please use the webclient, or the new 3CX "Desktop App"
Then click the "Panel" icon to see the active calls from there.
cur_cb
