3CX maintenance renewal
InfoLS
Forum User
We are wondering what happens with the possibility to active a perpetual license when the maintenance expires. Will that still be possible?
which one? which 3CX version?
Hi @InfoLS
Perpetual license, with expired maintenance will allow you to activate a new installation but only on the same PBX version that the key corresponds to. Example: a 15.5SP6 key will not work with the V16 installer.
You will not be able to use 3CX-based FQDN and SMTP so you will have to provide your own solution for those components.
Thanks for your reply. As far as i know, the standard version doesn't allow the use of custom SMTP and FQDN, right?
Correct, it does not allow custom FQDN + SMTP
Wecare_ITA
