3CX PRO 4 SC to 3CX Enterprise 4 SC upgrade
compumaxfl
Hi.. I have a client install (On-Prem) that will be expiring in a couple of weeks.. I am wondering if I can just upgrade this account to the Enterprise License (from Pro) without having to reinstall? In otherwords, it my 3cx Reseller Portal, can I use an existing (un-assigned) Enterprise License Key and assign it to this customer? The only option I see in the portal is that I can upgrade by purchasing a new license.
Thank you for your help! - Bill
Hi Bill.
Yes, you can upgrade the License to Enterprise and no reinstall will be needed, and all you will be needed to do is to reactivate your license key.
amazingbv
