3CX SBC Upgrade to V20
jclark
Gold Partner
I see that the new download links for installing SBC's are based on Debian 12 and say V20 on them when linked to a PBX. How do we upgrade our V18 SBC's to V20?
Hello, your existing SBCs will continue to work as before with PBX v20,
I understand that. This is not my question though. Is there a way to upgrade existing SBC;s to the V20 version of SBC that runs off Debian 12. As Debian 10 is EOL I feel it would important to upgrade SBC's as well.
The SBCs are simple enough to install from scratch that it's probably not worth the trouble of upgrading. I just setup twelve of them yesterday in assembly line fashion. I suggest:
1) Remove the existing Micro SDHC card and replace with one loaded with the current Debian Bookworm armhf version.
The current V20 documentation indicates "Raspberry Pi 5 with 4 or 8GB RAM", but my personal experience is that Raspberry PI 4 units still work perfectly well with the current software. While I agree with the 3CX 4GB RAM specification, I also know the 2GB versions will work in a pinch and I think springing for the 8GB RAM version is money wasted.
2) Update Debian Bookworm to current revision with:
sudo apt update
sudo apt full-upgrade
sudo reboot
3) Then load the new V20 SBC software from the guide and place it into service.
Replacing - rather than reloading - the existing Micro SDHC card yields at last two benefits:
1) Flash memory cards have a finite number of write operations. Linux writes logs almost continuously and so it's possible the existing flash card might be approaching it's limit and should be replaced anyway.
2) Retaining the original flash card gives you a fallback option if there are problems.
In my opinion, for the $10 max that these cards cost, the above benefits make outright replacement worthwhile.
Ken Morley
Carlos - EC Mates
