3CX Scheduled Backup
CTG2020
Is there a way to change the name of the 3CX scheduled backup file? The backups saved to an external SFTP server and if possible we would like to have the name changed to a unique value for different instances.
Thank you.
Not sure if this works, in parameters you could try changing the 'BACKUP_FILENAME' field
Thanks Saqqara - the change has been made and will see if the scheduled backup has the name changed.
Best have subfolders for unique instances in your SFTP server, with their own credentials for their folder. Don't let a single PBX see the folders of other PBXs or gain access to the the sensitive data contained in other backups.
The name change has worked, thanks again Saqqara. As you've noted John we'll have separate sub folders with their own credentials going forward. :)
Reactions: JohnS_3CX
bosdorf
