3CX Server - DB Service Starts & Stops
MarkCSUK
Client had reported problems transferring calls. I rebooted the 3CX server, all went fine.
Now none of the services will start as the DB service won't stay started.
In the event logs I have PostgreSQL 'error' events (ID 0) with the message "The Operation Completed Successfully"
I have backups of the system going back at least a month.
if this is likely to be a DB corruption I can remove and reinstall and use the backup to recover.
What OS is it on?
What AV are you running?
It might be quicker for you to reinstall and restore then to troubleshoot.
Reactions: Nathan@Voxtelesys
sherry reynolds
