3CX SMS thru SIP - Questions
Walnut
Platinum Partner
This is most likely a very silly question but all of the current documentation for setting up SMS through an existing SIP provider is outdated, at least that I can see. When setting up SMS on the webclient, after selecting my provider and navigating to SMS, it asks for the following information: User, Password, App ID, Account ID. If someone could explain what I need to enter into these fields I'd be grateful. Thanks!
You need to check the specific doc for your provider.
Thank you for the reply, is this something I can find through my provider portal or through 3cx? Also, I should have mentioned earlier but my provider is Bandwidth. Does SMS still not work with Bandwidth?
T2T
