3CX Softphone V5.8: SSO, Outbound Number Choice & BLF Transfers
ThomB_3CX
Staff member
Sign in with Google or MS365, choose your outbound number and set how BLF transfers work.​
3CX Softphone V5.8 is now ready for production. Following the Beta release, V5.8 brings easier Google and Microsoft 365 sign-in, outbound number selection and a clearer settings layout. The production release also adds a new option to choose the d...
This isn't very useful,
Which DIDs Are Available?​
Only DIDs assigned directly to the user's extension appear in the selector. A DID assigned to a department, queue or ring group does not become selectable simply because the user is a member. This keeps the available choices tied to explicit individual assignments.
We need the inbound call routing to work as before, but want the simple way for the user to select their outbound number. In most of my sites there most of the staff will be making calls for multiple brands and this implementation restricts it to just one extension
Reactions: DidierDE
I agree, it would be usefull for users to be able to select the DID of a queue for outbound calls.
Give it time, I'm sure a feature that can do this will come.
Its already possible to change outbound caller ID based on prepended digits, do this to get you by for now.
Reactions: DidierDE and bitn2
We have been testing and also come up against the issue of the outbound being bound to 1 user and not multiple users. We will take a look at the prepend digits as a work around @Alphabetic thanks for this
in update 10 you are able to select a queue DID if you part of the queue
Could we get DIDs of IVRs through queues? Example, if a queue 890 is on the IVR 701, members of 890 can use 701's DIDs?
Might be a bit complex tho lol
This does not seem to work for me.
We are on version 20.0 Update 10 (Build 1765 Beta - AI 1.6.91)
I am part of a queue with a DID assigned, but I can only select the default route and the DID assigned to me.
Maybe in the final U10 and not beta.
We are still using the old Windows client and I want to move to the new softphone version. Looking to use winget to do the install, but is there any way to auto populate the URL for our 3CX on prem server?
Reactions: bitn2
We updated to Version 20.0 Update 10 (Build 1785 Release - AI 1.6.91), but I still can't select the DID of the queue that I'm assigned to.
Im sorry its coming in U11, my mistake. We are well underway with U11 that's the good news on the other hand
MRGHSC
