3cx to grandstream
aminbaik88
how i can make a sip trunk between 3cx and grandstream?
the fxo line is on grandstream and some users is on it so need to make the users on 3cx can use the fxo lines on grandstream and can contact the users that is on grandstream.
thanks.
You should follow the gateway setup guides
thanks.
If you hope to connect a UCM to 3CX, just don't. Not worth it.
It's easier to move everyone to 3CX.
If you are really adventurous, have a good understanding of SIP, a great deal of patience, and are self hosted, you might be able to do this using a Bridge trunk. However, the use of Bridge trunks are now only supported between 3CX PBXs, so you you'd be on your own.
i cant move all users regarding logistic problem for now... so i want to makea connection between both.
i dot before with avaya but its not working with grandstream :(
i done the bridge and as peer sip and its working fine from ucm to 3cx but not from 3cx to ucm,
its always give me Cause: 404 Not Found/INVITE from ucmip:5060
any suggest ?
any suggest ?
As we all said, no one really ever got it fully working.
Reactions: N_G
VOIPEric
