3CX Trunk Issue with Cisco SIP Gateway
a.giledi
Hello Every one.
i have a Cisco 2951 that connected to ISDN service and provide a SIP gateway for my freepbx server. this scenario is works fine, inbound and outbound call works together without any issue.
i try to change the freepbx to 3CX, i was change only the IP address on cisco router to map to the 3CX, and configure the 3CX with the right configuration but the call was rejected immediately.
any idea to troubleshoot this case.
This is the current configuration that connected with freepbx:
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice class uri 1 sip
host ipv4:10.198.199.2
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn calling-number 3660009
voice-port 0/1/1:15
connection plar 107
dial-peer voice 3 pots
description Outgoing calls to PSTN
destination-pattern 09........
port 0/1/1:15
forward-digits all
dial-peer voice 1 pots
description incoming calls from PSTN
incoming called-number .
direct-inward-dial
dial-peer voice 2 voip
description incoming calls from FREEPBX
session protocol sipv2
incoming uri via 1
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 4 voip
description Outgoing calls to FREEPBX
destination-pattern 1..
session target ipv4:10.198.199.2
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 5 pots
description Outgoing calls to PSTN-Service
destination-pattern 1300
port 0/1/1:15
forward-digits all
sip-ua
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
sip-server ipv4:10.198.199.2
You might try using the 3CX Activity Log, to see what errors 3CX shows, on an outbound, and incoming call. That should provide a clue as to what might be wrong.
thank you for replay, i actually try this, but there is no log make sense
Well, the log might not make sense to you, but if you post it, it may make sense to someone on the forum.
On outgoing, it should show a dialled number sent to the IP of the gateway, and some sort of response.
Is there a log on incoming? If not, it may be a network issue.
What does the gateway (trunk) datafill look like in 3CX? Is the gateway local to the server? If not, then that will be a problem.
Reactions: a.giledi
lastshadow
