Solved 3CX Updates
ericms77
Hi All,
I did my very best to look for an existing conversation on my question, but had no luck. My apologies if I looked past it.
I am on 3CX Version 15. I've opened the requested ports on my firewall, but any time I click the "Updates" button on the 3CX Dashboard, I get the following error:
"Unable to reach 3CX Updates server. Check your internet connection and try again."
Hi, I found the solution for my problem: time on the server was far in future.
Sincerly Darius
Glad the issue was resolved for you and thank you for posting your solution
we can close this topic, on one server the time was not correct failing to create an ssl session and the other case was suffering from slow internet speed causing time outs in 3CX while downloading firmware files.
JLDSP
