Solved 3cx upgrade from 16v to 18v
HSM IT
Good Morning,
I am planning to upgrade 3cx from version 16 to 18.
Please let me know things I need to keep in mind before I do the upgrade and when I am performing the upgrade.
Self-hosted 3xc PBX on windows.
We are 24/7 monitoring company, so we would like minimum downtime.
We are so receiving the below error, will this resolve once we upgrade to18v ?
This has been discussed many times on the forum , if you used the search function.
make sure your windows os is supported for v18 https://www.3cx.com/docs/manual/phone-system-installation-windows/
steps
1. Backup existing 3cx with fqdn and liicense - move this backup to a folder outside of the 3cx folders.
2. Uninstall 3cx
3. Reboot machine
4. Install v18, selecting restore from backup - select backup from step 1
yes , licensing issue with be resolved
steps
2. Uninstall 3cx
3. Reboot machine
Thanks for the quick response @Saqqara
Also make sure if antivirus software is installed, exclude the following folders feom scanning
  • C:\Program Files\3CX Phone System\*
  • C:\ProgramData\3CX\*
Thanks @Saqqara
Hi @HSM IT,
Looks like everything has been mentioned, if you need anything else feel free to open a new thread!
RJenkinsROCK
