3CX v16 windows YealinkT29g not provisionig
nutechnet
Hi All,
need some urgent suggestions, i have a brand new install, win10 64 bit, 3CX V16, all phones show up and can be assigned to extensions, but wont provision. so far i have done this.
  1. upgrade firmware to latest for phones.
  2. Windows firewall is off.
  3. DHCP option 66 provisoned.
  4. DHCP opt 60 as well.
  5. Tried manual provisioning. not working.
I am running out of ideas and have no support left. any help would be appreciated.
cheers
attach a screenshot if you want so we can see, hide the unique provisioning folder ID
Are all services running by the way?
Are you trying the URL from a different PC or the one 3CX is installed on?
edit: Also, try the URL over both http (port 5000) and https (port 5001) to see if you get a different result.
Hi All, after trying everything and i gave up and reinstalled the debian distro, but the provisioning problem still remains. outgoing calls work fine incoming ring and go straight to vmail, i can provision the app using the code and make calls using the webapp. and receive as well, I also upgraded the Yealinks from their website apparently the have a firmware for just 3cx. but no avail, i am attaching some screen shots some help would be really handy right now :)
[Edited by administrator]
hughesdouglas
