Solved 3CX V18 cannot connect to web console after installation
TimoM
Have installed V18 on standalone PC, debian. Install completes and goes straight to login page and does not give option of configuring via web console. The PC is on same LAN as my laptop but i cannot connect using http:<ipadressofPC:5015>
I have tried the command to service 3* status from CLI and it brings nothing back.
Any Ideas
Regards
TimoM
Hi @TimoM,
Can you PM me the license key to take a look at?
I am having this same problem as of this morning.
Also, there is no option to upgrade v16 to v18 currently so cannot use an installer for v16 either.
Hi @Callinectes,
Update: After reinstalling v16, @TimoM resolved the issue on his side.
Are you still experiencing this issue?
Reactions: NickD_3CX
Great to hear @Callinectes, I'll close the issue and mark it solved.
Rich Hopkins
