3cx V20 - No option to route DID to forward external number
Formsdirect
We upgraded 3Cx from V18 to V20 last week. Everything is working correctly, except for DID call routing. We have a few incoming numbers and have always used their DIDs to directly route to external numbers. Since the upgrade, there is no option to forward to outside numbers as there was in V18. I have searched everywhere and cannot find the option to route calls directly to external numbers in V20.
Hi there.
So you mean the call will go to a specific user, and then you can set to send the call to an external number?
The call will not go to a specific user. I need to forward the call directly to the external number.
Forward the call to the empty extension that will then when not registered send it to the external number that you will specify in the call forwarding settings. Ensure your outbound rules are there too.
Instead of forwarding the call to an empty extension, is there any option to route the call directly to the external number as shown in the picture?
Reactions: Ibby-WaveLengths
You can use a group and forward it there, but its the same like another extension
Reactions: OlegR_3CX
Indeed, you can use this logic as V20 now does not have V18 inbound rule configurations and the forwarding needs to be configured on the destination point.
Carlos - EC Mates
