3CX v20 Update 3 - License Error
W4IT
I have a question regarding license activation for 3CX v20 Update 3. As stated we have most of our customers on 3CX v20 Update 3 and get the following error in the License field:
_i18n.LicenseHttpsErr_InvalidTrustedStorage
The licenses are all active and in the Dashboard it correctly states (for example)
Type Professional Annual 4 Simultaneous Calls (Expires on 3 Dec 2025)
or
Type Professional Annual 16 Simultaneous Calls (Expires 26 Nov 2025)
Is this a known issue?
The only way I could fix it was to upgrade our test system from Update 3 to Update 6.
Was this announced anywhere that the license activation for Update 3 will stop to work?
Thank you and best regards,
Stefan
Your pbx is one year behind, the certificates of the activation server changed. This could be your problem.
See the "3CX | IMPORTANT: Update your 3CX PBX by 3rd October, 2025" that 3CX sent July 2.
Edit: about once a year there is a required update.
Hello guys,
thanks a lot for the replies :)! I updated all my phone systems to update 6 (for now, because of the external storage) and all works fine now.
I honestly read that the update mail from 2.7. mentioned that you are safe if you upgrade to v20 Update 3.
I'm pretty sure there was a blog post at some point mentioning it but I couldn't find that yesterday.
It's fortunate you were still able to update, vs backup+reinstall+restore.
Reactions: fxbastler
Syedx91
