3CX V20 Update 6 RC Now Available
nikolascx
Staff member
3CX Support
CDR rewrite for better reporting. Sync & offload to PostgreSQL or BigQuery. Connect to Grafana.​
Update 6 has been one of the most anticipated releases in V20, with a major overhaul in call reporting. Following the success of the ALPHA and BETA, the Release Candidate is now available to download and includes improvements in Graf...
Just one issue, I tried to replace the key, and I found this issue :
Commercial Keys cannot be replaced.
Reactions: nikolascx
Its by design. Keys should be extended not replaced.....
New key = New customer
Existing key = Existing customer....
You can replace a trial key with a new key as its a new customer because that is not a customer yet....
From the Update 6.
And from Standard 4 SC to Pro 4 SC can we replace a license key from stock?
Has this data connector been confirmed to work with multi-company 3cx, with local postgresql? I asked in the previous thread, and I was provided with the standard db/server configuration instructions. However, I've now confirmed my PG db/server is working fine with another 3cx instance (single-company config), with no further changes to the server/DB configuration - the github setup script seems to have taken care of all the configuration suggested in the AWS guide and previous thread. The Grafana templates showed the data properly. But my multi-company 3cx transfers nothing (nor creates the tables) in my PG db... The data connector "test" works. The "transfer CDR now" does nothing, verified by tcpdump on the PG server. I am now on the RC.
Thanks for your work on this!
Reactions: N_G
We will check it, its something we want to support to allow for easy cross company reporting
where is the ability to
  • Choose your day of the week
I update the system and still can see only Monday
Grafana support is a real nice step.
Will you support offload to other databases, especially time-series databases, built for this kind of workload, such as InfluxDB ?
Thank you very much !
It would be cool, if in the future, I could define a postgres table prefix or something into the 3cx data connector config, to be able to use the same db/server across multiple client 3cx connectors. I'd just create a unique db username with appropriate permissions to their tables for each customer/instance.
Reactions: PhoneMan123
Release Candidates are typically considered Beta versions as they are just candidates, once the full release is out it will remove the Beta flag
Just an FYI. I updated to the RC and it still shows beta in the build number
On the second system testing I found this:
Any suggestions?
Reactions: jed and Evolute IT
I have been running inbound and Outbound daily scheduled reports for a week now in V20. The emails work, with the CSV attached, but I wanted to retrieve the csv files on the backend of 3cx. The files were available in V18. I could not find any reports in the following locations:
Windows
C:\ProgramData\3CX\Instance1\Data\Http\Reports\
Linux
\var\lib\3cxpbx\Instance1\Data\Http\Reports\
Are the reports located somewhere else now?
Thank you for any information.
Is it safe to use RC in production, guys?
We need the reporting piece badly.
I don't care much about the grafana piece. Anything similar to the v18 reporting would do just fine for us.
We are still using the latest U5 if you are curious.
Much appreciate the feedback.
Reactions: N_G
Not recommended for production. The final release is around the corner, I would wait just a bit more.
Best new feature has to be impersonate user! :D
No more second guessing what the customer is seeing on their screen.
I think you can use it, you can let us know any problems we will follow up
  • Love
Reactions: N_G and GregG_3CX
jb_erp
