3CX V20 Update 8 Release Candidate 3
MichaelB_3CX
3CX Team
Staff member
3CX Support
One last stop before Update 8 Final.​
We’re releasing RC3 to address the last minor fixes and improvements before Update 8 Final.
Fixes & Improvements​
  • Gateway Service Loop Detection: Fixed an issue where the Gateway Service could enter a loop during disconnection/reconnection scenarios, causing h...
Hi, any guess as to when the v20 u8 Final will be available? In production we're on v20 u6 (20.0.6.724) and want to update to u8 Final in our lab before upgrading in production. Since we need to be on u7 + hotfix before updating to u8, we want to combine both updates so we only have one outage window.
Also, I've seen mention of u9 - any timeframes for that?
Thanks,
Thanks,
While most software companies don't like to answer questions like that for fear of over promising and under delivering.
If you view the full change log https://www.3cx.com/blog/change-log/phone-system-change-log-v20/ you could reasonably deduce it will be 4-6 months based on past history depending on complexity and issues encountered along the development path.
Reactions: N_G and Evolute IT
Its going to be less then that, we are working in update cycles of a few months. Update 9 will be about webclient update and we expect March
webclient update ?
This could be anything, is this in term or design, functionnalities, i want to know more now :rolleyes::p
Reactions: janoack
Fingers crossed Update 8 Final will be today to make it a good weekend and to close out the month :);)
Reactions: N_G
| Don't Push To Production On Friday     |
|_________________|
              |_ |_
Re: the shared voicemail for a ring group, currently it makes a copy of the message in everyone's voicemail. It is marked on all as "heard by..." if someone listens to it, which is great. After that, other actions are not sync'd...marking it unheard, deleting it, etc. Those actions would be helpful in certain situations, such as, we have a phone in our lab and the message waiting light there would work if its voicemail was enabled, but the voicemail box would eventually fill up if no one empties it. A per-user voicemail retention setting could help address that, also. Just thinking out loud.
My system shows 1101 Beta installed, but does not show 1109 available. Should I be seeing the 1109 February update yet? Thanks.
I did get it :
Now I see it. Once refreshed. Thanks.
Reactions: KoesioOccitanieTech
The update to 20.0.8.1009 is the final release of Update 8.
UPDATING already!!!!!!
Thank you and KUDOS to the 3CX Team one more time!
I see it now. Thanks. Installed.
Reactions: Charles_3CX
tom.walker@blackcountryra
