3CX Vmware
KhaledQuenawy
if i install 3CX on vmware debian ... what kind of network on vmware should i select ( Bridge .. NAT .. Host Only)??
It depends on how you want to connect 3CX to your network. Do the same thing you would do if it was a physical box.
Hey KhaledQuenawy
The most appropriate connection for this setup is most likely to be BRIDGE as this will enable your VM to run on the network as if it is a real device (with its own MAC and IP Address) and allow you to use the same IP subnet as your other devices.
Hope this helps and good luck on the install.
Cheers
Hi Khaled
You would probably choose bridged so the machine gets both its own MAC and IP as a separate network device.
[email protected].
