3CX Web Client login/out of Q
Robertos
hi,
we have agents setup with multiple queues.
Is it possible to login out of ALL Qs using the Q button or it only logs in./out of Q on active page?
I want to enable this for queue manager to set agents Q status and for agents to b able to log in and out of ALL queues and not just individual ones via Web Client...
See this weblink: https://www.3cx.com/docs/pbx-queue-status/
There are several ways to login and out of a specific queue. Default the Q is for all queue's but
once you logout of a specific queue this will not work anymore.
Thanks for the link Sven.
Well i guess if they are using the Web Client it will default to individual queues. This is frustrating and can get out of sync. I wish i could override this behaviour to Global Queue Login/Out via Web Client.
It gets too complicated for agents and managers otherwise who do not require such a feature.
Hello @Robertos
The Q button does log agents in and out of all queues unless someone explicitly logs someone out of the queue.If that happens then this will work for all other queues except the one the agent was explicitly logged out. If managers do not explicitly log agents in and out then you should not have this issue.
Reactions: Robertos
Thanks Yiannis. What is cleanest way for managers to GLOBALLY log agents in/out ?
The cleanest way to globally log out a different extension is through the management console.
Thanks again Yiannis
You are welcome, glad i could assist
laranicole.lucus
