3CX Windows App 5.6 (Build 1162) Stops Starting - Reinstallation Only Fixes It Temporarily (V20 Update 9 Build 995)
Philiqqz
Hello everyone,
We are currently experiencing an issue with the 3CX Windows App (MSIX/AppX version from the Microsoft Store) and have not yet found a permanent solution.
Environment​
  • 3CX Version: V20 Update 9 Build 995
  • 3CX Windows App: Version 5.6 (Build 1162)
  • Deployment method: Microsoft Store
  • Operating System: Windows 11 25H2 (Build 26200.8655)
  • We operate two separate 3CX systems:
    • One Cloud-hosted instance
    • One On-Premises instance
Problem Description​
For some users, the 3CX Windows App suddenly stops launching.
The behavior is always the same:
  1. The user clicks the 3CX application.
  2. The Windows cursor briefly shows the loading spinner.
  3. After a few seconds, the spinner disappears.
  4. The application never opens and no error message is displayed.
Observations​
  • The issue appears to occur randomly for certain users.
  • Other users with the same app version are not affected.
  • Uninstalling and reinstalling the 3CX app resolves the issue temporarily.
  • However, the problem reappears a few days later.
  • We have observed the issue on users connected to both our Cloud and On-Premises 3CX systems.
  • So far, we have not identified any common pattern among the affected users.
Troubleshooting Performed​
  • Uninstalled the 3CX app
  • Reinstalled the app from the Microsoft Store
  • Re-provisioned the affected users/extensions
These actions restore functionality only temporarily.
Questions​
  • Has anyone else experienced this behavior?
  • Are there any known issues with 3CX Windows App 5.6 (Build 1162) and 3CX V20 Update 9 Build 995?
  • Are there any specific logs we should review to identify the root cause?
  • Has anyone seen similar problems with the Microsoft Store version of the 3CX app?
  • Is there possibly a known compatibility issue with Windows 11 25H2?
Any suggestions, recommendations, or troubleshooting steps would be greatly appreciated.
Thank you in advance for your help.
Hello @Philiqqz,
Will send you a DM so we can take a closer look.
Reactions: Philiqqz
Same issue here, will submit a ticket
Same issue here. Last working app version 5.5
this resolved.
$path = "$env:USERPROFILE\Downloads\Microsoft.WindowsAppRuntime.Singleton.1.8.msix"
Add-AppxProvisionedPackage -Online -PackagePath $path -SkipLicense -LogPath "C:\Temp\Singleton_Provision.log"
thanks!
More info on this thread:
cur_cb
