3cx with yeaster s300
mohamed hamed
i have 3cx latest version (windows) and s300 (firmware version) V1.40 0000-0000 , i want to use s300 FXO trunk to make outgoing calls from 3cx.
i tried this steps https://support.yeastar.com/hc/en-u...nnect-3CX-and-Yeastar-S-Series-VoIP-PBX#step1
but it's not working .
can i use Type of Authentication registered account based to create inbound rule in s300 to route to extension instead of route to outgoing rule , if yes how can i do it.
thank you
Hi @mohamed hamed
We really cannot advice on how to set this up as we do not support this configuration and was never tested by us. I would recommend adding a supported FXO device to your 3CX to be able to make outbound calls.
postmaster@studiolegaleda
