Solved 3cxSystemService.log: |540|0013|Info|Push is disabled for extension ...
[email protected]
SOHO User
Hello
We facing a problem receiving calls on Android 3CX Client: all client are able to make call but few (5 of 12) receive the calls.
Our configuration is Pbx 3Cx Pro 16.0.4.493 while androids are 16.2.0.93.
We configured our own Firebase push account and all portable are provisioned with the correct and similar configurations.
The investigation done on android version was unsuccessful: no correlation with android because phone with the same version have different behaviors (one receive, the second doesn't).
At the end we found the problem related to extension: phone not working with a extension, start to work (receive calls) when it is provisioned with working extension.
We investigated in 3cxSystemService.log file and, on receiving calls, for working extension the log reports:
...|540|0036|Info|Sending PUSH to extension ... device .....
while for not receiving extensions the message is:
...|540|0013|Info|Push is disabled for extension ...
That could mean a different configuration between two extensions: but we checked option by option and working and not working extensions have the same configuration.
So we suspect an "hidden" option not exposed in the pbx configuration pages.
Any suggestion is welcome.
Thanks in advance.
Michele.
So there's really only one setting, and that's this one:
If that is set, then try unchecking it, saving, and then checking it and saving and see if that helps.
Reactions: [email protected]
Also note, that our various Statuses have a separate switch for PUSH because you may not want the phone to ring at all under a specific status:
So if the user disabled PUSH on their own extension under a specific Status that they are currently on, it will not ring.
Reactions: cobaltit
thanks for the replies.
we found the problem in the "Enable PUSH for smartphone" options that is visible in extension "Phone Provisioning" configuration when the "3CX App" is selected. All extensions select the desk phone so the option was hidden. switching to "3CX App" then enabling for some extensions the PUSH option and than back to desk phone fix the problem.
thx again
Reactions: JohnS_3CX
Glad to hear it was resolved
intoxtech
