401 Unauthorized Error with 3CX API Despite Correct API Key
MayurMali
I am developing an integration between 3CX and Google Sheets to automatically fetch call recordings and details (such as caller ID, callee ID, call duration, and recording URL) based on phone numbers listed in a Google Sheet. I am encountering a 401 Unauthorised error when attempting to access the 3CX API, despite using the correct API key. I have verified the API key and its permissions, but the issue persists. Here are the details of my setup and troubleshooting steps:
Details:
Endpoint URL: https://bassprac.3cx.com.au:5001/api/CallControl
Request Method: POST (also tested with GET)
Headers:
Authorization: Bearer MY API KEY
Content-Type: application/xml
Details:
Headers:
Where did you find this endpoint? The Call Control web API isn't there yet AFAIK.
Hey, thanks for the reply. Then how can I build the integration?
You need to use other endpoints. In your case, might be easier to use the CRM Integration with a custom script to talk to Google Sheets. Otherwise, check the ReportCallLogData endpoint.
Thanks again. Can you guide me where can I find ReportCallLogData endpoint, as I can't find proper documentation for 3cx to build my integration.
i am getting 401Unauthorized error and i can't figure out what the issue might be
endpoint i am using https://bassprac.3cx.com.au:5001/api/ReportCallLogData/Pbx.GetCallLogData
also pasting my xml script if it might help
XML Script:
<?xml version="1.0" encoding="utf-8"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="US" Name="3CX Call Integration" Version="1" SupportsEmojis="true" ListPageSize="0">
<Number Prefix="AsIs" MaxLength="11" />
<Connection MaxConcurrentRequests="2" />
<Parameters>
<Parameter Name="APIkey" Type="String" Parent="General Configuration" Editor="String" Title="API Key:" />
</Parameters>
<Authentication Type="Basic">
<Value>API Key</Value>
</Authentication>
<Scenarios>
<Scenario Id="LookupByNumber" Type="REST">
<Request Url="https://bassprac.3cx.com.au:5001/api/ReportCallLogData/Pbx.GetCallLogData" MessagePasses="0" RequestEncoding="UrlEncoded" RequestType="Post" ResponseType="Json">
<PostValues Key="">
<Value Key="periodFrom" Passes="1" Type="String">2024-01-01T00:00:00</Value>
<Value Key="periodTo" Passes="1" Type="String">2024-07-01T23:59:59</Value>
<Value Key="sourceFilter" Passes="1" Type="String">[Number]</Value>
<Value Key="callsType" Passes="1" Type="String">All</Value>
<Value Key="hidePcalls" Passes="1" Type="Boolean">false</Value>
</PostValues>
<Response>
<Value Key="StartTime" Path="$.value[0].StartTime" />
<Value Key="SourceCallerId" Path="$.value[0].SourceCallerId" />
<Value Key="DestinationCallerId" Path="$.value[0].DestinationCallerId" />
<Value Key="TalkingDuration" Path="$.value[0].TalkingDuration" />
<Value Key="RecordingUrl" Path="$.value[0].RecordingUrl" />
</Response>
</Request>
</Scenario>
</Scenarios>
</Crm>
Active Telecoms
