Solved 5-Digit length override
andron18
New User
Greetings everyone,
We are looking for a replacement for our legacy PBX, it is currently used with 6-digit number plan.
Is there any official and supported way to overcome 5-digit limit in 3CX ?
Thanks!
Not really, the maximum extension number length is 5 digits. I'd see the migration as an opportunity to drop it to a more manageable digit length. :)
I do not believe this is possible (in a supported way). You can do it with the 3CX Call Control API, but I have never tested it, and I am confident 3CX would frown on this approach.
Reactions: andron18
Thanks for prompt advise.
Reactions: ChrisC_3CX
Do you need 6 digits or do you need to maintain existing extensions? If you just need 123456 to ring user_a, then you can use the SIP ID to map that.
I need to maintain existing extensions.
Fortunately, our format allows to undercut one digit.
Seeing that you've managed to work this out, I'll be marking this as solved.
Please don't hesitate to start a new thread should you need anything else.
Rich Hopkins
