Abandoned call discrepancies
Jim Taylor
I have a system with 50 or so users, multiple queues, IVRs, etc. There are 2 users who are both set as Receptionist, both have 100% visibility to all departments. On the Panel in the website, one user sees 3 abandoned calls. The other user sees 0. If you pull up an Abandoned Queue Calls report, it shows zero for today. The only report I can get to show anything totaling 3 calls being missed is a User Activity report, which shows 1 Unanswered call in the 6am hour, and 2 Unanswered in the 9am hour. If I go into the call logs those appear to be where a direct extension was dialed but not answered/went to voicemail. I'm not 100% certain if those User Activity Unanswered calls are what's populating the Panel, as I thought the Panel Abandoned calls were queue related, but again, the call reports show no abandoned calls even thought the panel shows 3. Why would one user see 3 and the other 0? Need some help clarifying this as the customer doesn't know how to interpret the results, nor do I.
What view are they using in Panel View?
View all or specific q?
in the 3CX settings > View what queues and calls are selected to be viewed?
Both users are set to View All, and View settings both match identically with everything checked.
The one who can see the abandoned calls in their history has been added here as a supervisor:
Both users in question are only in this section for one queue, but both are listed, so their view should technically be the same.
Unless that’s not the queue with the real abandoned calls.
You could remove both from the one you mentioned earlier and check if the user who had 3 abandoned calls still shows 3. If they do, that means the calls came from a different queue.
