Access to a passive server in failover mode.
Phil-STIC
Platinum Partner
I'm getting ready to update systems to V20 with the failover function. Maybe the solution will jump out at me when I do the update, but I'd like to know how we'll be able to access the passive system, if the fqdn is associated with the active system, since in version 20 it's no longer possible to connect to a system with the IP address...
I'm sorry if the question has already been asked, but I haven't found the answer.
Thank you.
Use the IP in HTTPS. It will work, it will just give you a red banner at the top, that's all.
I knew the solution had to be right under my nose...
The banner "3CX Version 20 requires a secure connection to use the Web Client. You are not using an FQDN or HTTPS to connect to 3CX." intimidated me, apparently!
Thank you @ConceptsWeb
Syedaashir
