Actual steps to rebuild SMS with Telnyx in U6
mcsphones
Gold Partner
Hello. We've updated our various instances to U6 and SMS isn't working, to which we were wisely alerted to pre-update. However, none of the SMS/SIP trunk setup guides for Telnyx actually show us what to reconfigure in U6. That is, the cautions to rebuild our SMS setup say to rebuild the SMS setup, but frankly they aren't specific enough to actually let me know what to configure specifically. Hope that makes sense. Thanks.
Go to your SIP Trunks in the Management Console, select the Telnyx trunk, go to SMS tab, Copy webhook URL and paste it to Telnyx Messaging Profile, then go to Telnyx Keys & Credentials copy your API Key and past it, this worked for me,
in your 3CX SMS tab, the webhook is the main thing that changed
Reactions: mcsphones
Telnyx is supposed to support their trunk and SMS setup. They are supposed to make a guide and publich on their site.....
I know, However just showing what worked for me, I am sure as time goes on I am sure it will happen. I see a lot of people having trouble getting SMS working after U6, the fact is it is not very hard to get it working again.
@SnakeRiverWebDevelopment Yes indeed - its helpful you posted this. But it should be clear its something to do on telnyx side and supported by Telnyx.
Syedx91
