- Joined
- Feb 12, 2021
- Messages
- 57
- Reaction score
- 13
There is no column for Queue Name but what you can do is prepend or append the Queue name to the Caller id with the option in Advanced >> Contacts >> Options:
That way, you'll have the Queue name in the caller ID shown on the left for each call.
My apologies, I missed the fact that you mentioned CRM, though, I did check and can confirm that you should see the Queue name on the left underneath. I even tested with CRM contacts:
• What exact version of the PBX are you running (check under "Dashboard >> Information >> Version")?
• Does this apply for all Queues?
• Does this apply for callers who only exist as a contact on the PBX (not in Dynamics)?
i tried in Crhome in incognito and in another PC and not show de queueCan you test with the latest version of Google Chrome in incognito mode? Do you still get the same behavior? I might also suggest testing on another PC.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
